Hey i just bought a new windows 8.1 laptop so that i can use virtual dj and try to take over the world......
However my laptop will not recognize the audio portion of my Behringer CMD sTUDIO 4A controller!
All th buttons knobs faders and jogs seem to work just fine, but i am not able to assign the headphone and output for some reason!
I love my controller it is cheap loaded with features and right now i can't use it with my new lap top because of this issue.
Any suggestions?
Any suggestions?
geposted Tue 08 Apr 14 @ 1:28 pm
Have you installed the ASIO driver?
Does Windows recognise there's an external audio device when the 4A is connected to the PC?
If Windows recognises it, then so should VDJ.
geposted Tue 08 Apr 14 @ 1:42 pm
The driver is here:
http://www.behringerdownload.de/CMD/CMDStudio_ASIO_Driver_v1.5.0.zip
geposted Tue 08 Apr 14 @ 2:37 pm
everytime i try to install that driver it fails. not sure why. it just does.
geposted Wed 09 Apr 14 @ 11:32 am
cam you post a screenshot of the error you re getting ?
geposted Wed 09 Apr 14 @ 11:33 am
here it is
geposted Thu 10 Apr 14 @ 10:11 am
i tried the latest drive and the one before it neither will go though the installation process.
geposted Thu 10 Apr 14 @ 10:13 am
Drivers mention Win8, but not Win8.1, so i would contact Behringer to find out if the error is OS related
geposted Thu 10 Apr 14 @ 2:19 pm
tired to no direct line to there tech support....
geposted Fri 11 Apr 14 @ 10:49 am
Have you tried right-clicking the Driver installer and select "Run as Administrator" ?
geposted Fri 11 Apr 14 @ 1:47 pm
will try it now.
geposted Sat 12 Apr 14 @ 8:43 am
i am administrator on this pc. i think it is the fact that the driver is not for 8.1.
geposted Sat 12 Apr 14 @ 8:53 am
Thats not what Phatso suggested.. Rightclick on the drivers installation file (you need to save it to your computer first), and choose "Run as administrator" even though you are ;)
But anyways, if there is still a compatibility issue with the ASIO drivers , you can still use the WDM drivers. You will need to adjust a few things though.. read here.. http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Sat 12 Apr 14 @ 7:53 pm
i am only seeing stero as an option, no quadrophonic as a speaker setup option on my lap top.
geposted Sun 13 Apr 14 @ 6:02 pm
You performed the operation mentionned by djDad on the CMD soundcard, not your computer's, correct?
geposted Mon 14 Apr 14 @ 2:28 pm
Yes on the CMD CARD, it did not show 4 speaker icons
geposted Wed 16 Apr 14 @ 7:06 am
Hi!
I bought yesterday Behringer CDM Studio 4a DJ Console and unfortunately the console doens't work and I have an windows 8.1 laptop!!
Can someone help me, before i'm getting mad?
geposted Sat 06 Sep 14 @ 4:33 am
Behringer have a care team at this address -> care@music-group.com
They also have their own forum - forum.behringer.com
geposted Sat 06 Sep 14 @ 4:48 am
Any suggestions?
Any suggestions?
Hi and sorry for this delayed comment but I want to mentioned that I have same controller as you and I used it with VDJ 7 and had some issues with the ASIO drivers. Since I bought VDJ 8 everything is fixed. The controller is found by VDJ 8 and all work perfect, even scratching :)
I hope you have already solved your problem.
Kind Regards,
Nicolas
geposted Tue 07 Apr 15 @ 3:30 am
Hi. I have a problem. I am running Virtual DJ 8 with a Behringer cmd studio 4 mixer.
Everything seems to work ok for about an hour and 20 minutes, and then suddenly the sound disappears and there is no audio until you reset everything.
Is the problem compatibility issues with Virtual DJ and Behringer hardware?.
Everythig works ok for about 1 hour & 20 Minutes? .Everything works as it should up to 1hour & 20 minutes, after that, no sound?.
I have tried this several times on different computers. Very strange?.
Any ideas?.I would appreciate any help you can give.
Many thanks/
John
Many thanks/
John
geposted Fri 07 Oct 16 @ 4:14 am
