Hi, is there any plugin to change both filter and key???
I mean, i own a pioneer ddj ergo and, there's no way i can change the key of a song..
I would be very appreciated that someone advises me, how can i do it...
Best regards.
Best regards.
geposted Thu 24 Apr 14 @ 9:13 am
Key change is built into VIrtualDJ and does not need a plugin.
Simply use the key knob on the default VirtualDJ v7 skin and/or map a knob that you don't use to the action key
You can also map two separate buttons or keys on your computer's keyboard to key_move -1 and key_move +1
NOTE: For best results and sound quality, make sure that Advanced Stretching is enabled in CONFIG -> Performances.
geposted Thu 24 Apr 14 @ 11:06 am
you can use the key "shift"
shift + filter = key
geposted Thu 24 Apr 14 @ 11:42 am
Hi..
I'm afraid that isn't quite correct..
Shift+filter is not equal to key... unfortunally..
However.. it can be programmed to do so..... is that correct??
Best regards.
Best regards.
geposted Thu 24 Apr 14 @ 7:44 pm
you must make a variable with the key "shift"
down ? set 'var.........
geposted Fri 25 Apr 14 @ 12:40 am
Exactly. He's suggesting you use a modifier key to give the control multiple purposes.
Shift key:
set myshift while_pressed
Filter/key knob:
var myshift ? key : filter
Shift key:
Filter/key knob:
geposted Fri 25 Apr 14 @ 2:45 am
Thank you guys for your help..
I really appreciated.
geposted Fri 25 Apr 14 @ 4:55 am
Hello. This work in virtual dj 8.2??? Thanks a lot!
geposted Fri 17 Jun 16 @ 1:56 am
