Forum: German Forum
Topic: Übersicht der aktuellen bzw. laufenden Builds und Fixes der Version 8 - Page: 3
jakovskiPRO InfinityModeratorMember since 2006
20.08.2014
Build 1926
-Fix context menus on mac
-Depth buffer available on windows (for video effects)
-Aftertouch midi message handled for sliders
-Fix slow waveform/cover update of Pioneer CDJ's on mac causing player to stop responding for a while when browsing or loading a track
-Fix first couple of milliseconds at start of some mp3 files being cut off
-Fix pitch_zero "center" when pitch is not yet picked up by controller when takeovermode on pick up
-Font Size and Text Position options added to Text plugin
-Fix context menu not disappearing after opening sub-menu
-Reload tags fixed
-Small improvement to midi detection on mac
-Fix rename of sample set
-Shuffle Once option added for automix list
geposted Thu 21 Aug 14 @ 2:23 am
22.08.2014
Build 1932
- new "vdj7" algorithm for motorized platters (in config/options/advanced/controllers)
- fix click-through in skin context menu
-Fix crackling sound in some cases when latency was configured manually
-fixed video samples in sampleSets zips
-fixed loading images from sampleSets zips
-optimized showZipKaraoke not to reopen all zip files every times
-Custom context menu resizes on expand/collaps of sub-menus
-Improve path storage in playlists
-Automix fix when using mixNow when playlist was finished
-Possible database corruption fix
geposted Fri 22 Aug 14 @ 2:18 pm
29.08.2014
Build 1941
- new timecode engine
- faster LED refresh on MIDI/HID controllers
30.08.2014
Build 1944
- improvements on the timecode engine
- improvements on the motorized jogwheels engine
geposted Sun 31 Aug 14 @ 6:30 am
02.09.2014
Build 1946
- more improvements on timecode
- more adjustable settings in config->options->timecode
- fixed regression bug with jogwheels being locked for 1s after loading a deck
02.09.2013
Build 1949
- more timecode improvements
geposted Tue 02 Sep 14 @ 6:06 am
10.09.2014
Build 1957
- fix timecode drift in relative mode
- can adjust timecode pitch parameters in options
geposted Wed 10 Sep 14 @ 4:34 pm
12.09.2014
Build 1960
- new timecodePitchDelay option
- small fixes to the timecode engine
Auto Update Problem wrote :
Wenn der automatische Download nicht klappt dann direkt hier: http://virtualdj.com/download/virtualdj8/pc/1960/zip
Info wrote :
In the new b1960, you now have 3 settings for the timecode visual pitch slider.
The recommended values are:
timecodePitchSensitivity: 3%
timecodePitchSpeed: 10%
timecodePitchDelay: 0.5 seconds
but if you like to see your pitch more reactive on the skin, you can change timecodePitchDelay to something smaller, probably 0.1 seconds.
(of course, this means that the rhythm on the skin would also move when you stop to scratch or if you pitch-bend)
geposted Fri 12 Sep 14 @ 6:55 am
RobRoyPRO InfinitySenior staffMember since 2012
21.09.2014
Build 1970
- fix timecode absolute mode
-Fix mixNow not working when automix editor was used
-Fix automix editor size cursor not resetting to default cursor
-Fix load security window popping up twice on exit
-Fix file parsing bug
-Improve playing deck selection for external mixers with video crossfader
-Fix videoAudioOnlyVisualisation when the effect was already active on a deck
-Fix potential high CPU usage with timecode
-Fix automix editor playback pointer after re-opening
-Exit sysex messages send after turning off leds
-Don't overwrite stored audio config automatically on apply
-Only one custom button editor per button can be opened
-Video effects can be activated from controller, even when video engine not opened yet
geposted Sun 21 Sep 14 @ 12:03 pm
24.09.2014
Build 1973
- faster search on large databases
- fixed song loading when loaded out of order
- prevent creating hotcues past end of song
- fixed some rare crashes
- re-analyze removes corrupted flag if file is not corrupted anymore
geposted Wed 24 Sep 14 @ 2:25 pm
08.10.2014
Build 1996
- fix regression bug on Windows XP
Build 1995
- Improved timecode engine
- New timecode config interface, with automatic calibration
- New algorithm for timecode pitch slider (with or without option timecodePitchSliderIgnoreBend)
- Changed timecode smart mode needle-drop behavior
- Vibration threshold for hid jogspeed
- Fixed some potential random crashes
- Better search in database when using accents and/or greek/russian/hebrew alphabet
- Allow sampler_pad 1 "4x2x2" for skins that need a specific pad layout
- Fix possible crash when analysing corrupt files
- Fix mp3 seek bug
- Fix not being able to set cue points before the start of the song
- Fix video mixing with autoMixDualDeck
- Fix videoAudioOnlyVisualisation sometimes activated for a very short time when loading a new video
- Fix high cpu usage when using 2 pioneer controllers with same mapping
- Fix reverse on motorwheel controllers not being instant
- Fix drag files from Finder on mac with retina screen
- Fix loop_select having same range as loop_half and loop_double and not rolling over for endless encoders
- Fix iTunes database problem with recent iTunes update
- Fix 'other' plugins not correctly loaded when put in AutoStart
geposted Wed 08 Oct 14 @ 1:14 pm
11.10.2014
Build 2003
- loops use local bpm
- fixed glitch at end of drop samples
- fixed possible crash callibrating unrecognized or mixvibes timecode
- fix crashing bug in Stanton's libhs1394
- timecodeAntiSkip can specify the sensitivity
- fixed timecode problems when pitch>+-20%
geposted Sat 11 Oct 14 @ 4:49 am
19.10.2014
Build 2013
-Fix loops on variable bpm songs
-BPM display updated on variable bpm songs based on position
- fix potential crash in skins with mouseMask
-updateHotCueOnCueCombo option to disable cue+hotcue overwrite behavior
-Video Sampler drawn on top of visualisations, but still before other video effects
-Fix import iTunes ratings not working for some files on mac
-When multiple sound card definitions exists with the same vid/pid, prefer the one for which the hid/midi controller is also detected
-Fix automix editor prelisten not stopping
-Fix automix editor prelisten reading out of bounds sometimes causing glitches during mixes
-Improve scratch latency for pioneer ddj-sz
-Fix slicer when using multiple buttons simultaneously
-Audio only visualisation can be accessed through slot name "audioonlyvisualisation"
-Fix bug with audio only visualisation being loaded multiple times causing it to use all cpu
-Fix prelisten player not stopping when closing editors
geposted Sun 19 Oct 14 @ 11:05 pm
28.10.2014
BUILD 2021
-Fix compatibility with new iTunes libraries
-Lowered minimum level for timecode (to work with serato soundcards)
-Show calibration when selecting timecode for first time
-Fixed timecode button on audio config to use the correct soundcard
-Fix crash when trying to use 'audioonlyvisualisation' slot
-Fix automix not playing video when the same song is repeated
-Cue0 not locked by lock_cues
-Cue0 properly reset on loading a new song
-Allow dropping a sample in a specific location in list view
-Reload Tags correctly imports grouping and rating
-Fix videoVolumeLink and videoLevel broken during transitions
-Fix crash trying to play files that would decode to over 4GB
-Mac soundcard reconnect when soundcard unplugged and replugged
-Loop Roll and Slicer implemented as position plugins to reduce latency
-Fix certain actions followed by param_ actions not being executed
-Fixed bug in tablet skin causing cue button to overwrite hot cue 1
-get_decks action returns the number of decks the skin was designed for instead of number of decks active in the software
-sync action doesn't move position when track is stopped
-fix crash when updateHotCueOnCueCombo is off
-Fix bug causing some videos not to play in sampler, and take some time to start playing in the decks
-support NI controller digits
-use hidef icons in dialogs on mac with retina display
-fix audio config dropdown doesnt disapear on mac
geposted Tue 28 Oct 14 @ 2:41 pm
31.10.2014
Build 2028
- automatic timecode detection and calibration on first setup
- native compatibility with Rane SL2 and SL3 audio interfaces
- performance improvements for skins with lots of nested panels
geposted Fri 31 Oct 14 @ 10:41 am
11.11.2014
Build 2029
- added compatibility with traktor timecode vinyls v2 ('mk2')
geposted Tue 11 Nov 14 @ 5:49 am
13.11.2014
Build 2030
- import cue points from serato tags
- various small improvements to the timecode engine
geposted Thu 13 Nov 14 @ 8:39 am
14.11.2014
Build 2031
- more choices in advanced option "getCuesFromTag" to allow import serato/traktor cues on existing database entries
- automatically compensate for badly wired needle (inverted phase) for traktor mk2 timecodes
geposted Fri 14 Nov 14 @ 5:25 am
16.11.2014
Build 2048
-Fix some OS X 10.10 issues
-Fix HID color output
-Improve HID digit output
-Fix beatphase detection bug
-Fix VST plugin parameters not remembered
-sampler_mode action can work on individual samples
-sampler_loop can toggle loop on/off
-Fix activating slicer or loop roll can cause drop-out for a short time
-Fix slicer sometimes not turning on or off
-Fix slicer when used inside loop
-fix sampler_mode for specific samples
-"None" option added for videoAudioOnlyVisualisation
-Small looproll fix
-fader start doesn't trigger loading of a new song
-slicer "step" fix
-effect_select_multi "video" +1 fixed
-fix loop roll position marker sometimes not disappearing
-slicer x "pressed" action to check difference between active slice and highlighted slice
-fix beatlock unable to pause/stop deck
-fix possible glitch when slicer button released
-fix possible crash when reading corrupt id3 tag
-Fix crash with some djc actions
-Fix visual type='color' on mac
-Filter folders using 'top' are automatically sorted now
-Reverb effect parameters shown as starting from 0 instead of from center
geposted Sun 16 Nov 14 @ 9:37 am
23.11.2014
Build 2059
-Midi clock output (right-click on controller in config window to activate)
-fix problem reading m3u playlists exported by iTunes
-less CPU usage when using complex skins
-effect_select actions with absolute effect number
-global sampler volume also affects video
-fixed potential problem with text transparency on mac
-sampler_group_volume index starts from 1 instead of 0
-get_sampler_bank_id and get_sampler_bank_count actions added
-fix motor scratch lock when deck is cloned
-fix plugins not remembered for more than 2 decks
-video editor allows images to be overlayed
-Some high-dpi fixes for Video Editor
-Fix playback of vdjedit files in some cases
-HID relativetouchslider
-Reverb and loop roll parameters start from 0 instead of center
-Improve selection of comment tag for mp4 files
geposted Sun 23 Nov 14 @ 11:25 pm
26.11.2014
Build 2064
-Slideshow has option to play video
-Midi clock output setting stored in config
-Fix utf-8 titles not correctly truncated in status message
-Delete available for samples in search too
-File operations not performed on db when failed
-Fix some browser touch screen issues
-Fix sideview shortcuts with ' in their name
-Fix effect_select +1 sometimes lighting up
-Midi jog wheels that use 'inverted' note fixed
-Fix video edits with only image added not displaying as video
-Fix flickering in video editor preview
-Fix file deletion crash on Mac OS X 10.7
geposted Wed 26 Nov 14 @ 7:27 am
BraenzuPRO InfinityModeratorMember since 2007
27.11.2014
Build 2067
-Fix bug with pitchQuality 1 for looped samples
-Fix some video slideshow crash
-Fix video slideshow time to max not playing videos till the end
-Fix regression unable to resize skins
-fix for midi text out using sysex
-fix switching sampler from unmute trigger mode to different mode
-fix some sampler crashes
-fix sampler_rec not working when remix mode selected
geposted Thu 27 Nov 14 @ 12:01 pm
47%
