I have a small gig set-up that uses the Hercules DJ Control Steel with Virtual DJ 7.4. I just saw the post for the new VDJ 8 download. I want to know if the old Steel Controller will work ok with the new version of of VDJ. I have a gig on Saturday and the last thing I need is to spend time troubleshoooting stuff. Last time I downloaded a new version I had to update my soundcard drivers.
geposted Wed 14 May 14 @ 2:03 pm
Yes, it is in the list of supported controllers in v8
BUT
VDJ8 is a pre-release. It's kind of like a beta, but for a large usergroup (all pro users).
If you look at the pre-release forum it lists lots of bugs in all different shapes and sizes, and updates to the software are coming out every few hours
So I wouldn't recommend using v8 for a gig. For gigs stay with v 7.4 until the full release of v8 comes out
BUT
geposted Wed 14 May 14 @ 2:48 pm
When I load a tune on to virtual DJ deck there is a lag before it loads. When a song is playing and I load another, the platter stops spinning for a few seconds. The music continues however. I have a toshiba i7 with 32 gigs of ram.
geposted Tue 31 May 16 @ 2:04 am
inxscpl wrote :
. I use vdj7 and 8When I load a tune on to virtual DJ deck there is a lag before it loads. When a song is playing and I load another, the platter stops spinning for a few seconds. The music continues however. I have a toshiba i7 with 32 gigs of ram.
geposted Tue 31 May 16 @ 2:11 am
And what audio interface are you using exactly?
Does it have an ASIO driver, and if so , did you try modifying the buffer size ?
geposted Thu 02 Jun 16 @ 8:24 pm
Native instruments audio 2 DJ. Another problem I have is that Some songs load but I only see about 1/4 inch of the bar on the loaded deck. It plays fine and the bar shows up entirely on the last few seconds of the song. It does not happen for most of my songs. It has usually happens with new downloads. I get my music via Amazon. Does not matter if I am using my Hercules control Steel with the Audio 2 DJ or my Hercules RMX2 which has its own audio interface.
geposted Sun 05 Jun 16 @ 12:46 pm
Before you load the track to a deck and play it, has it been analysed by VDJ?
geposted Sun 05 Jun 16 @ 1:37 pm
If I analyze before loading it plays fine, but I have to analyze every time I play the song.
geposted Mon 06 Jun 16 @ 10:25 pm
