Topic: past play dates (mac)
just updated to the latest update 1761.644 and i'm still having issues with past play dates, i have removed and added tracks back to the db but tracks i played wednesday night are showing as last played 01/03/2017 the dates range back to 2016, i also checked the tags and the tags are also listing first seen as various dates from 2016, if i do play a track though it is showing correct play date.
this is on mac osx mavericks with latest update on a macbook pro late 2011
geposted Fri 16 May 14 @ 5:08 am
If it's not in the changelog, chances are, that it has not been fixed :)
geposted Fri 16 May 14 @ 5:25 am
Just booting my Mac up to take a look because the issue was fixed in a build between 1752 and 1761.
Or at least my machine was ok
geposted Fri 16 May 14 @ 5:32 am
Just updated to 1761 on the Mac and my dates are correct.
Previously my first seen dates were 2015-2017 they are now as they should be 2012, 2014 etc
geposted Fri 16 May 14 @ 5:47 am
ok well here are some of my issues, mavericks updated to 10.9.3 this morning, i'm still showing past play dates as ranging from 2016-2017 these all display as they should in 7.4.1, i've also noticed a lot of played tracks are not showing last play date (again this works in 7.4.1) another issue i've just picked up is when i change the recordcase display (i drag artist to the left to display first column) after rebooting vdj 8 it reverts back to title first.
geposted Fri 16 May 14 @ 6:25 am
Kev,
Can you close VDJ8.
Locate the database.xml file in /documents/virtualdj/
Delete it (don't worry it will copy your V7 database over again)
Then Reload V8
Does that fix it?
geposted Fri 16 May 14 @ 6:27 am
ok deleted databse xml file date issues still the same, all files were put on this machine november 2013 example dates of a track played wednesday night first seen 1/9/2016 first play 21/12/2016 last play 01/03/2017 22:29 this is however on my mackbook, i'm also testing vdj 8 on my imac late 2013 with different results all files put on this machine last sept and i'm seeing different date range, again deleted xml & reopened vdj 8 this is running mavericks 10.9.3 also and latest vdj, example dates on this machine first seen 22/07/2014 first play 22/07/2014 last play 22/07/2014, actual tag data from within vdj 7 first seen 30/11/2013, first play 30/11/2013, last play 30/11/2013
geposted Fri 16 May 14 @ 6:58 am
i will just add the issues i'm getting are only relating to historically played tracks in vdj 7 that have not been played in vdj 8, anything i play within vdj 8 is listing the last played time & date correctly but first seen dates & first play dates are still wrong
geposted Fri 16 May 14 @ 7:07 am
Ok - i've logged again and we'll see what happens. They might need some more specifics as i am now unable to re-produce.
Someone will ask if thats the case though.
geposted Fri 16 May 14 @ 7:11 am
Kev, got a message from the developer.
Can you make 100% certain that you deleted the database.xml and then reload version 8.
If you reload V8 so you can still see you Finder, then you should see the database.xml re-generate.
geposted Fri 16 May 14 @ 8:01 am
Yes did that 3 times on both machines on one machine I also deleted the version 6 database file, but still have the date issue
geposted Fri 16 May 14 @ 8:41 am
mikadadPRO InfinityMember since 2011
I did exactly as you instructed, deleted the database.xml file and then reloade VDJ8, some of the files got fixed, but as you can see some are still on a 2015 date and some just have a date then the time...
geposted Fri 23 May 14 @ 2:35 pm
and I am on the latest build. thanks
same issue on the PC side I have first seen dates that say 2017. whats that all about???
geposted Thu 30 Apr 15 @ 7:17 pm
