Forum: Old versions
Topic: Virtual DJ locks up when scanning / analyzing library
Just bought a new HP laptop (Intel I5, 8 gig ram, 750 gig hard drive running Windows 7) and running Virtual DJ pro basic. I loaded my music library to the hard drive (over 15,000 songs). I select the main folder to scan and analyze BPM's and walk away (I takes a while. I come back to notice that VDJ has locked up. I have to cntrl/alt/dlt and then re-open. After the 3rd time I noticed that it was stuck on a wma file. I'm not sure if it always got stuck on a WMA and I try to just use MP3's but I guess a few files sneak into the database.
Any known issues?? Any solution?
geposted Sat 17 May 14 @ 7:39 am
This is usually caused when your hard drive goes to sleep because it isn't being accessed.
It's called power save mode.
A quick search on Google and you should find the way to switch this off for your operating system.
geposted Sat 17 May 14 @ 8:45 am
