Topic: PC-to-PC Broadcasting not working. - Page: 1
Hello,
I'm trying the PC-to-PC broadcasting and it's not working with the URL http://www.virtualdj.com/homepage/djemergency/broadcast.html
I'm running a Macbook Pro Retina Late 2013 maxed out.
Also I would like to suggest a chatroom for the page as well so users can come in and chat while listening to the stream. :D
geposted Sat 17 May 14 @ 10:12 pm
Try changing broadcastDirectFormat to mp3.
geposted Sat 17 May 14 @ 10:37 pm
Thanks. I have that now and it says "Loading.." but not doing anything else..
geposted Sat 17 May 14 @ 10:58 pm
I know we are still ironing out the bugs with this.
Can you confirm you are broadcasting now and i will try and listen.
I am able to broadcast and hear my own stream
geposted Sat 17 May 14 @ 11:06 pm
Yes I'm broadcasting now. If you like I can stay on and test it for you.
geposted Sat 17 May 14 @ 11:07 pm
geposted Sat 17 May 14 @ 11:09 pm
geposted Sat 17 May 14 @ 11:10 pm
Could just be a slight connection drop. Does it come back?
geposted Sat 17 May 14 @ 11:11 pm
actually yours works great now. Just that I had to shut down VDJ8 for it to work. I dunno why but VDJ8 lags my whole system once I start sliding through full screen apps.
geposted Sat 17 May 14 @ 11:13 pm
Ok - have you broadcasted before?
geposted Sat 17 May 14 @ 11:14 pm
on VDJRadio yes, but never PC-to-PC. Even with 7 I couldn't get it to work and when someone would connect it would crash it.
geposted Sat 17 May 14 @ 11:16 pm
geposted Sat 17 May 14 @ 11:18 pm
djtouchdan wrote :
I am unsure of the ins and outs of VDJRadio. But did you have to open a port on you internet router for it?
For direct broadcasting you need to open port 8000.
http://www.virtualdj.com/wiki/Broadcasting%20Howto.html
Tried that now and it crashed twice when connecting..
geposted Sat 17 May 14 @ 11:23 pm
VDJ crashed?
That should happen if your trying to adjust your router.
geposted Sat 17 May 14 @ 11:26 pm
djtouchdan wrote :
VDJ crashed?
Yes. I opened the ports and it crashes VDJ as soon as I used my iPhone to connect to the website to test it.
geposted Sat 17 May 14 @ 11:28 pm
Are you broadcasting now? I'll test from here again
geposted Sat 17 May 14 @ 11:30 pm
Just turned it on. Try it out :D
geposted Sat 17 May 14 @ 11:31 pm
No nothing.
Are you sure you got the ports opened correctly?
I got a new router a few months back and took me hours to figure the thing out! lol
geposted Sat 17 May 14 @ 11:33 pm
djtouchdan wrote :
No nothing.
Yes I have UDP and IP open and it just crashed when I typed this. LOL
I think I figured out the crashing problems on the Mac when closing and the lag issues... It could be due to Parallels being installed..
geposted Sat 17 May 14 @ 11:36 pm
Are you running through Parallels?
geposted Sat 17 May 14 @ 11:44 pm
47%
