Need help. I want to grab fx on the fly (With a mouse). Unfortunately, the drop down menu doesn't contain the native filter effect. Does anyone know how to achieve this.
P.S. Yes, I posted this earlier, but the post has mysteriously vanished. I did a search and it was not there. Moderators, feel free to move this thread as I will use the yellow bell from now on.
geposted Tue 20 May 14 @ 9:05 pm
Pretty sure it's not possible. As it it's built in rather than an effect.
geposted Tue 20 May 14 @ 9:19 pm
I don't know if SBDJ monitors this, but is something like a simple DLL possible to be created to link the two? Not looking for a second filter...just a way to access it the built in one from menu.
geposted Tue 20 May 14 @ 10:17 pm
It's possible to create, but why not just use one of the onscreen filter controls instead?
geposted Wed 21 May 14 @ 9:57 am
Trying to modify a skin so that I can assign any effect to any slot. Works great, minus the filter. I want to completely remove a section I never use and replace it with something more usable.
![](/image/61126/136388/example layout.jpg)
geposted Wed 21 May 14 @ 3:20 pm
