You can use the padfx script for that (see the stems fx pad page for more details)
geposted Fri 29 Sep 23 @ 2:20 pm
Hi all,
I'd like to see dual purpose rotary dials that show more than one value please.
An example using the Pro skin where an EQ encoder is being used for both stems and EQ:
It would be nice to see both values depending upon which mode is being adjusted wtih an internal and external curve representing values.
In the third badly hand drawn example below, it shows the MID EQ setting is non zero at a glance whilst the stems adjustment is currently displayed.
geposted Tue 07 Nov 23 @ 6:10 pm
that's just a skin thing and can be done right now but only visually
geposted Tue 07 Nov 23 @ 8:03 pm
I wish to see crossfader updates / Crossfader fusion like the vocal cut transition which helps to fade the vocal of out going track and bring in the vocal of the in coming track during a scratch after releasing the Jog wheel
geposted Sun 11 Feb 24 @ 2:33 pm
explain it better and I could make it.
geposted Sun 11 Feb 24 @ 3:27 pm
