There are many users who still have that resolution.
a greeting.
a greeting.
geposted Mon 26 May 14 @ 6:13 pm
Yep, that is the resolution of my laptops! :-)
geposted Mon 26 May 14 @ 8:39 pm
Resolution isn't a issue anymore, the skins rescale automatically. 1 skin suits all. If you're having glitches or oddities post a picture and description of the problem.
geposted Tue 27 May 14 @ 7:27 am
@locodog
not true
if you have a 1920x1080 or what ever and see it on a 13" 1280x800 you are not able to work with fonts of all main information in player look like 6pt.
thats why we whant smaller skins (they normaly usese a better resolution for the system fonts in the player section.
Browser is no issue any more but the plaxyer and the information
@rest
try the skin "denn yo"
klick on the platter und you get better resolution for the time value
Edited for language.
geposted Tue 27 May 14 @ 8:42 am
Even the browser is affected when using the new skins at lower resolutions.
The vertical tabs which separate the areas become too small to read and very narrow.
geposted Tue 27 May 14 @ 8:58 am
When the skin rescale from 1920x1080 to 1280x800 the waveform is completely useless looks tiny, some screenshots with the same song:
VDJ8 waveform:![](/image/41194/137433/Captura de pantalla 2014-05-27 a la(s) 20.13.33.png)
Others programs waveform:
![](/image/204/137435/Captura de pantalla 2014-05-27 a la(s) 20.10.48.png)
VDJ8 waveform:
![](/image/591/137436/Captura de pantalla 2014-05-27 a la(s) 20.05.53.png)
geposted Wed 28 May 14 @ 3:32 pm
When I try to map something:
![](/image/85512/137438/Captura de pantalla 2014-05-27 a la(s) 20.23.08.png)
The box is cut
The box is cut
geposted Wed 28 May 14 @ 3:37 pm
Catap, i think you need to post this in the Beta - bug report forum. It seems that its unrelated to any skin so the Skins forums is not the proper one to use.
geposted Wed 28 May 14 @ 5:04 pm
ok Bob, thanks for your answer ;)
geposted Wed 28 May 14 @ 6:50 pm
