I've recently downloaded virtualDj 7 LE on my laptop for the first time. I usually just use my home desktop but now want to be portable. For some reason though none of my lights on my g2v will light up. I've tried what google has to offer but no luck... No one else seems to have this problem because theres nothing about it on the forums, which leads me to believe its an easy fix and i've just missed something.
geposted Fri 06 Jun 14 @ 12:21 am
Most likely, you will need to update the firmware of the unit .. http://geminisound.com/support/g2v-g4v-led
geposted Sat 07 Jun 14 @ 1:48 am
Having the same problem, have you managed to figure out what was wrong? The suggested download did not work for me.
geposted Fri 14 Nov 14 @ 12:15 pm
Try to contact Gemini
Email: Support@geminisound.com
http://geminisound.com/tech-support
geposted Mon 17 Nov 14 @ 2:38 am
Also experiencing same issue
log a complaint with Gemini support, but stll waiting response
geposted Wed 19 Nov 14 @ 12:02 pm
