CLASSIC VIRTUAL DARK v0.1a - 2 Decks
Hello this is my first skin / first skin modification
Here a modification of the default virtual dj 8 skin. I changed some texts colors and sizes for a better visibility.
It's an ALPHA version, it's possible that there have oversights.
2 deck skin audio and video at 1920x1080
Version 0.1a (alpha)
geposted Sun 08 Jun 14 @ 7:06 am
very nice !!!!
when will it be online?
geposted Sun 08 Jun 14 @ 10:24 am
Very good
geposted Sun 08 Jun 14 @ 7:07 pm
hello
The skin will be available soon, I hope what will be validated by the team
geposted Mon 09 Jun 14 @ 7:51 am
I wish someone would re-do the buttons... They are all severely fuzzy! :-(
geposted Mon 09 Jun 14 @ 9:34 am
The best is to wait until the team broadcasts the wiki page for the new skin language
geposted Mon 09 Jun 14 @ 10:29 am
small modification of certain color button colors unit and non-gradient
geposted Mon 09 Jun 14 @ 11:20 am
to be honest, i am not sure if we will ever approve skins, just because a background color is changed (and maybe a few others).
Btw, the background color can be changed also from the xml file, so no need to edit the png image files.
Use this code..
<visual type="color" source="get_constant 'value'" >
<pos...>
<size...>
<mask ... >
</color>
Mask is optional , in case you need to have some semi-transparent graphics or a specific non-rectangular shape.
value (inside the source) can be either a pre-defined colors like blue, red, green, white, black, white, cyan, etc, or an html color code.. e.g. #aaaaaa, #569834 etc.
So, if you add a color visual on the top of your skin ( actually before start adding buttons , textzones etc), it will color the backround depending on the value you have set.
Use this code..
<pos...>
<size...>
<mask ... >
</color>
geposted Mon 09 Jun 14 @ 3:17 pm
hey so why is the browser grey? its hard on my eyes, can you give step by step to make it black? thx
geposted Fri 25 Jul 14 @ 7:13 pm
Where in the xml file do we implement the code and could you show us more of an example?
geposted Sun 27 Jul 14 @ 12:59 pm
Have a look at djdad's Combat skin - the skin of many colours!
geposted Sun 27 Jul 14 @ 2:05 pm
