Forum: Old versions
Topic: Open Pio Editor
Wenn I use the command var 'hotcue_delete' ? edit_poi for a Button on my Controller.
How can I Close the Edito with the self Button?
geposted Mon 21 Jul 14 @ 7:29 pm
You cant. And i really see no reason mapping a controller's button to open the POI Editor, as this is mostly used for preparations. I guess you dont want open the POI Editor during a gig right ?
So its designed to operate with mouse mostly. The action is there for the skins mainly.
To set a Remix Point ;-)
Can open the Window, why should i not can close this too?
Why can't remix points be added in the same way as hot cues?
With Pio i can my own Remix Point make ;-)
