Ok, so I have a lot of effects and custom scripts assigned to different buttons on my Numark NS7, and one of them is that I changed the 'Sync' button to be 'Flanged LoopOut' instead. I have all 4 decks set the way that I like them, each parameter is set to a specific number. But when I load up VDJ8, unless I move a knob or something (like I have one set to 0.0%) it PLAYS its default settings, even though the numbers on all the knobs are just the way I left them. As soon as I move a knob or something it goes back to the way I have it set though.
Example:
I load up VDJ, play a song on deck 1, push sync, and it plays the effect, but at that effect's default settings. Close VDJ. Open VDJ again, load the same song in deck 1, only this time I load the effect into the GUI and move the knob from 0% to whatever and back to 0%. Play the song, push the button, and it plays the effect with the numbers I have set.
I don't get it. It does that with all 4 decks, and it doesn't matter what song it is, or even if it's a video.
Anyone have any ideas? The VDJScript is just a simple *effect "blah" active* script, so I don't see why it would remember all the numbers on the knobs, but not actually PLAY it that way.
Example:
geposted Sun 07 Sep 14 @ 9:55 pm
