I get my CPU i red the moment i open up VDJ. can't even play videos any help.
these are my specs.
Model Name: MacBook Pro
Model Identifier: MacBookPro5,4
Processor Name: Intel Core 2 Duo
Processor Speed: 2.53 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 3 MB
Memory: 8 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP53.00AC.B03
SMC Version (system): 1.49f2
Serial Number (system):
what am i doing wrong?
these are my specs.
L2 Cache: 3 MB
Memory: 8 GB
Bus Speed: 1.07 GHz
geposted Fri 12 Sep 14 @ 5:44 pm
Open activity monitor in iOS and see what's using the CPU. Vdj8 should be using enough by itself to redline
geposted Sat 13 Sep 14 @ 4:20 am
vdj is using 82% of my cpu
geposted Tue 23 Sep 14 @ 3:37 am
On vdj 7 or vdj 8 ?
geposted Tue 23 Sep 14 @ 4:34 am
VDJ 8
when am playing audio it takes about 42% of cpu but when i load a video it goes to 82%
geposted Wed 24 Sep 14 @ 5:06 am
go into settings then options type fps in the search box. In the line that says skin change the number from 30 to 19. This should help drop the processor usage down into the low 30's
that is what worked for me on my 2010 Macbook pro
geposted Wed 24 Sep 14 @ 1:43 pm
thank you but that didn't help i change the fps from 30 to 19 but cpu usage is still at 70-82 %
geposted Thu 09 Oct 14 @ 3:16 am
My mac is 2010 , similar specs the only difference I think is mine uses nvidia 320 graphics, I do spike slightly when loading videos, but the cpu stays right around 30% while playing. When youre playing mp3 what is your cpu usage?
geposted Thu 09 Oct 14 @ 10:48 am
