I use Virtualdj 8 with a Macbook, & the software keeps crashing anytime I try to delete any folders
geposted Tue 30 Sep 14 @ 8:53 am
Mine does the same, anytime i try and remove songs of folders its crashes. Have you found a fix?
geposted Fri 17 Oct 14 @ 8:43 am
Mine same its a bug ,o how can i fix this ,also its nothing on this favorites its emptys where its my songs
geposted Sun 19 Oct 14 @ 11:46 pm
Hello there, any solutions to fix that problem, yet? VDJ8 on iMac the program keeps crashing, any time I try to delete any kind of folder within the folder tree (virtual folders as well as favorites).
thx very much
best wishes
Andy
thx very much
best wishes
Andy
geposted Sat 13 Jun 15 @ 7:52 am
the other posts in this thread are from last year what version are you running?
if its not the latest i would try an update
if you have the latest it is probably a permission issue
geposted Sat 13 Jun 15 @ 11:39 am
