Is there a simple way to be able to export the controller settings so that they could be used for a different device?
For example, my performance controller is a Pioneer DDJ-SR, but I also have an AKAI MPD26 that I wanted to play around with (by using some of the same mapped functions that the DDJ-SR controller has configured.)
Things like setting cue points, slicer, etc. are what I'm looking for, but if I could get a chunk of text showing the mapped functions I could use that as a starting point for creating my own custom mapper.
Thanks in advanced!
Daniel (DJ I.T.)
Thanks in advanced!
Daniel (DJ I.T.)
geposted Sun 05 Oct 14 @ 1:50 pm
For any device that you have altered it's default mapper there should be an xml file on your Documents\VirtualDJ\Mappers folder.
You can open this file with any text editor to get it's contents.
Personally I would recommend you to use Notepad++ (free) that can visualize the xml data.
geposted Tue 07 Oct 14 @ 7:28 pm
