Hey all having two very odd problem with a VDJ install on a laptop. When recursing a folder with subfolders it always returns a different amount of files. Also when using Add To Search DB on an External Hard Drive (does not effect internal) the DB records a different amount of files each time I use the add to DB feature. I have found a workaround by double clicking after i hit Add to search DB which put the scan prompt in the background (prompt goes completely grey) and it works everytime. I have tested 2 of these external hard drives on my main Laptop and have none of these issues. I know this is not normal behavior since my main system has had this same version install since its release. Any help or points in the right direction are greatly appreciated.
geposted Mon 20 Oct 14 @ 5:57 pm
