can somebody help me set this mixer up the right way using midi, I downloaded the mapper and drivers from Adj website and I still cant get it right, everything works fine but the audio on deck two comes out of the master when its in cue.
geposted Wed 22 Oct 14 @ 7:21 pm
It depends on how you want to use it.
If you need to use it as a pure analogue dj mixer, then MIDI needs to be de-activated and an External mixer audio configuration (deck 1, deck 2 ) is required.
If you need to use it as a MIDI mixer, the MIDI needs to be turned on (from the middle button) and a Master & Headphones audio configuration needs to be applied.
You also need to switch to USB Source if you want to use it as a MIDI unit.
http://intranet.americandj.com/ItemRelatedFiles/8329/dv2_usb.pdf
geposted Wed 22 Oct 14 @ 9:51 pm
Thanks dj dad i want to use it full midi but using the asio doesnt work, when i press pfl on the mixer i get audio thru the master 1 and 2 and 3 and 4 as well, if i dont use asio master works good but no audio n headphones.
geposted Thu 23 Oct 14 @ 5:26 pm
sent you a pm
geposted Thu 23 Oct 14 @ 5:46 pm
