Hi,
I want to create some audio samples for use in the sampler.
I have converted my MP3 to ogg format - but I need to add the Binary Header that is required by VDJ so that it can be recognised and play correctly.
I wish to automate this process as I have quite a few to do.
Has anyone else achieved this?
Plus it would be nice to auto-create the XML file that sets out the samples so that they display in the right sequence in the sideview panel.
Currently I am doing this by hand - surely there is a better way?
Thanks
Thanks
geposted Thu 30 Oct 14 @ 6:43 am
You don't need to convert your samples.
Just use the original files. The sampler will play them. They don't need to be in the VDJ format.
geposted Thu 30 Oct 14 @ 6:54 am
Ahh thanks - you live an learn.
I am sure I can automate the XML file using some basic text tools
Thanks again.
Thanks again.
geposted Thu 30 Oct 14 @ 7:12 am
