Hi guys, ive had this problem for a while and need help to reslove it. Im running a Denon MC6000 MK1 with the 8.2vdj mapper. and the left channels DECK 1 & DECK 2 seem to be playing out regardless of fader position. Now i can adjust the channels eq and can hear the changes, so that says to me that the channels are playing out the PFL (pre fade) rather than Fade. anyone come across this or willing to assist in resolving it.
This appears to only happen on midi and not line output
any help is welcome
thanks
MBP 13
VDJ 8
Denon MC6000
Simon
any help is welcome
thanks
MBP 13
VDJ 8
Denon MC6000
Simon
geposted Sat 01 Nov 14 @ 4:42 pm
Can you please direct me on the mapper ? Is it a custom mapper ?
geposted Tue 04 Nov 14 @ 5:00 pm
its not a custom mappper. this is the one i have installed
http://www.virtualdj.com/forums/192176/addons/Denon_DN-MC6000_Enhanced_Mapper.html?page=1
thanks
thanks
geposted Wed 05 Nov 14 @ 5:56 pm
Then it IS a custom mapper! :)
Please open Config, and click on mappers icon.
On the top of the window select your DENON and on the right side next to it use the drop-down menu to select "factory default"
Does your unit still has problems ?
If the answer is no, then there's a bug on the mapper you downloaded, or you messed something in it.
If the answer is yes, please try to rename your Documents\VirtualDj\settings.xml file to something like Documents\VirtualDj\settings_backup.xml and try again.
If you STILL have issues then most likely you unit has developed a hardware fault and you will have to take it on a service center.
geposted Wed 05 Nov 14 @ 7:09 pm
