it stopped working the the middle of a gig. Doesn't work with VDJ 8 or 7. Doesn't move on the screen when I use the controller but can move it with a mouse?? Does this mean I need to replace the crossfader? the mapping is set to full and enabled?? Any suggestions folks??
Thanks
John
Thanks
John
geposted Thu 27 Nov 14 @ 1:15 pm
Does the crossfader work for normal audio use (using the 6000 to play external sources)?
Have you checked that the fader is sending MIDI data (use MIDI-OX or similar)?
geposted Fri 28 Nov 14 @ 5:27 am
