Working towards PostFX I'm trying for 1 script for all buttons and for some HW it works but for some it doesn't. and I think its mappings that aren't shared (shared meaning left & right buttons, 1 script)
Here's an similar example I've found with the customs. ( C1 & C6)
leftdeck ? deck 1 effect_active 1 'echo' : deck 2 effect_active 1 'echo'
If I click with the mouse it works correctly (C1 does the left C6 the right)
but if I map the keyboard (one key to C1, another to C6) both keys only effect the active deck. Can I script around this?
I'd like to keep so there's just one script that will work for all.
The HW causing the problem is the DJM T1
geposted Sat 29 Nov 14 @ 11:01 am
Found the solution
action_deck 1 ? deck 1 effect_active 1 'echo' : deck 2 effect_active 1 'echo'
geposted Sun 30 Nov 14 @ 2:10 pm
