I'd like to make a button which will cycle through the songpos waveform choices.
Is the only way to name each selection or can I use 'cycle'?
geposted Sun 30 Nov 14 @ 8:20 am
you can use a variable with a cycle : cycle '$WAVECOLOR' 4
and 5 panels :
<panel id="color1" visible="var '$WAVECOLOR' 0">
<panel id="color2" visible="var '$WAVECOLOR' 1">
etc
and 5 panels :
etc
geposted Sun 30 Nov 14 @ 12:14 pm
I'm talking about the 5 choices available in the config options.
coloredWaveforms = monochrome, neutral, ultra-blue, infra-red or per-deck. I'd like a button to cycle through those.
I know I can use action="setting 'coloredWaveforms' monochrome" for example to set a specific one, but I want to switch between all 5 with one button.
geposted Sun 30 Nov 14 @ 12:24 pm
there is no cyclicng action for the setting, so all you can do is something like..
setting 'coloredWaveforms' 'monochrome' ? setting 'coloredWaveforms' 'infrared' : setting 'coloredWaveforms' 'infrared' ? setting 'coloredWaveforms' 'perdeck' ...etc
geposted Sun 30 Nov 14 @ 12:42 pm
OK thanks Babis - I think it would useful to have cycling, as it would easier to write the code (and for users to understand).
geposted Sun 30 Nov 14 @ 1:07 pm
groovindj wrote :
it would useful [...], as it would easier
I assume that's a correct english sentence... What's the rule behind ?
geposted Sun 30 Nov 14 @ 2:20 pm
Oops, I missed out 'be' - twice! :-)
It would be useful to have cycling, as (or because) it would be easier to write the code....
geposted Sun 30 Nov 14 @ 2:53 pm
Oh I thought it was a formula lol :)
geposted Sun 30 Nov 14 @ 2:56 pm
My brain is tired after staying up very late last night playing with XML. :-)
This is the result:
The original skin is Live Remix by DennYo, which had the decks on the left, one above the other.
I moved deck 2 to the right hand side, removed the rhythm waves, made the songpos waves narrower, moved three buttons from the popup 'settings' panel to the top bar and moved the other options to the area between the decks - so now there's no separate panel for settings.
It's now just a two deck skin and everything works nicely in VDJ 8. The 'wavecolor' button switches between the five songpos wave colours. :-)
I did this to use on my laptop which is 1280x800.
This is the result:
geposted Sun 30 Nov 14 @ 3:12 pm
Release this bad boy right now ! >< (© LSL50)
geposted Mon 01 Dec 14 @ 6:25 am
geposted Mon 01 Dec 14 @ 7:03 am
