Hi,
I own an infinity pro license and use the full pro, latest versions on both V7 and V8, along with the Denon MC6000MK2 with the latest firmware update, everything set to factory settings. When using the controller on V8, channels 1and 3 have no sound. All controls work and I get sound on 3 and 4. When using V7, I only get sound on channel 1, but not on 2, 3 or 4. The VU meters for each channel indicate sound, but not the master. All of the controls work and sync flawlessly with the software.
Is there something I am missing to get all four decks working??
Thanks!
Thanks!
geposted Sun 30 Nov 14 @ 11:44 am
You need to use a "Headphones" sound setup with MC6000MK2 and not an external mixer setup.
Also if you don't use ASIO you should not install any drivers on your system (or uninstall the ASIO drivers)
geposted Mon 01 Dec 14 @ 9:48 am
