Okay, I'm sure someone will give me a simple link to the right answer, that he found with a quick google search, but for any reason my last two days of research on the forum and the rest of the internet didn't bring results.
Anyway, I wanted to know if there is a way to map all 16 pads of the Numark orbit, so that each one triggers a cue point (1-16) on ONE deck. While I can use the pads on both sides for each one out of 16 different samples in the sample bank without problems, the VDJ mapper only shows 8 pads per bank ("PAD1_BANK1" till "PAD8_BANK1" for all four banks) .
And it works fine for two decks. When I push the button that is PAD1_BANK1 on the left side it does goto_cue 1 & play_stutter on deck 1 and if I push PAD1_BANK1 on the right side, it does the same on deck 2. But for now, I don't wanna use deck 2 with this controller at all and instead want to use all the buttons, that are linked for deck 2, also for deck 1, but for different cue points!
I hope you anderstand what I mean and that someone can help me.
geposted Thu 04 Dec 14 @ 3:19 am
You should use the following code as an example to adjust your mapper:
PAD_1:
device side 'left' ? deck 1 hot_cue 1 : deck 1 hot_cue 9
PAD_1:
geposted Tue 09 Dec 14 @ 5:50 pm
