Forum: VirtualDJ Skins
Topic: songpos vertical ????
dj fandosPRO InfinityModeratorMember since 2006
Hi!!! I have this question. put someone achievement, songpos in vertical?? wiki explains it well. I do not get it
Special - in principle exactly the same as above but some additional options.
The syntax of the songpos element is <songpos deck="" orientation="" waveform="">
deck is the deck number the element will apply to
orientation : Possible values:
horizontal, for a simple horizontal slider
vertical, for a simple vertical slider
circle, for a circular slider
round, for a knob-like button
It has all the properties and definitions of a <slider>, plus those:
<down x="" y=""> : Give the graphic to use for portions of the song not played yet, and without any volume
<volume x="" y=""> : Give the graphic to use for portions of the song not played yet, and with a maximum volume (the display will be a fade between down and volume)
<selected x="" y=""> : Give the graphic to use for portions of the song already played, and without any volume
<volumeselected x="" y=""> : Give the graphic to use for portions of the song already played, and with a maximum volume (the display will be a fade between selected and volumeselected)
<upselected x="" y=""> : Give the graphic to use for background of the played part
<cues> : Define the sprites to be used as CUE markers. Includes the following definitions :
<size width="" height=""> : Give the width and height of the cue sprite
<up x="" y=""> : give the cue sprite graphic
<down x="" y=""> : give the graphic to be used when the cue is pushed
<over x="" y=""> : give the graphic to be used when the mouse is over the cue
<clipmask x="" y=""> : Give the coordinate of the B&W graphic that should be used as a clip mask when drawing the cue
geposted Tue 09 Dec 14 @ 3:07 am
FruitPRO InfinityMember since 2003
You may try to use a visual instead.
Songpos is a buggy thing now.
geposted Tue 09 Dec 14 @ 3:37 am
geposted Tue 09 Dec 14 @ 12:19 pm
So any jog wheels that use songpos circles will not work any more because they use waveform="no"?
That means a lot of old skins will need changing.
How much longer are we expected to wait for a completed VDJ 8 skin SDK page?
Still nothing in there about split browsers. Last update was nearly 3 months ago!
geposted Tue 09 Dec 14 @ 12:41 pm
