Forum: Old versions
Topic: How Do I Undo Download Lyric function?
Hi Guys,
I applied a download lyric function to all of Mp3 and most of them are not the right song or out of sync with the song how do I batch undo this?
Thanks
geposted Wed 10 Dec 14 @ 1:10 am
There is no batch process to remove lyrics. You ll have to check each of the traks you ve downloaded and if the lyrics are not correct you ll have to do that one by one from the Tag Editor
geposted Wed 10 Dec 14 @ 7:52 am
Hi DJ DAD this solution is tough as it has affected thousands of songs. I high lighted all of them and the system batch downloaded Mostly incorrect lyrics for most of my songs. The problem is now the [non music video feature-slide Show] doesn't work as VDJ thinks that video is present in the form of lyrics.
Please try to create an undo feature. I don't mind if you remove or disable the feature entirely. Or Remove lyrics from all of the songs.
Thanks
geposted Thu 11 Dec 14 @ 11:42 pm
Lyrics are saved as separate files in your Hard Drive to the exact folders as the tracks. So maybe you could delete them using Finder. They all have the same extension .lrc
geposted Fri 12 Dec 14 @ 8:29 am
seems to be working thanks DJdad
geposted Sat 13 Dec 14 @ 7:33 am
