Hi, 2 things:
1: When I pick a song to play, and try to mix it, but then change my mind and pick another song, if I have played it too long while cuing it flags it as "played already" I usually remember, but if I had a very long night, i COULD forget that I DIDnt play it after all, but it is listed as played. I asked support about this int he past, they said you can delay the time it will play before it "reads" it as already played, but then they said actually they were mistaken, and it wouldnt work... IDEAS?
Also,
I like to refer back to PLAYLISTS I did for certain gigs/parties to see what really worked well together (mixing wise). The problem is, that if a song as i stated above was cued for too long, it says it was part of the playlist, but it WASNT, and may not have been the song I chose to mix at that moment...
IDEAS?
Thanks all, Merry Xmas
Also,
IDEAS?
geposted Tue 23 Dec 14 @ 1:12 pm
