Marry x-mas!
Is the a way to get the choosen automix type or set the type by script?
Same problem with faderlength.
geposted Fri 26 Dec 14 @ 4:25 am
its not faderlength --> FadeLength
is the a way to get this parameter?
geposted Fri 26 Dec 14 @ 6:39 am
You may only "poll" if a mode is actually in use, such as :
setting 'automixMode' 'smart' ? blink
Or you may directly set a value :
Same applies to fadeLength.
geposted Fri 26 Dec 14 @ 9:08 am
setting 'automixMode' 'smart' ? blink 10ms : setting 'automixMode' 'force fade' ? blink 50ms : setting 'automixMode' 'skip silence' ? blink 100ms : setting 'automixMode' 'full songs' ? blink 200ms : setting 'automixMode' 'no mix' ? blink 0ms
I chose to make something blink for an example but you could launch any action you wish instead.
geposted Fri 26 Dec 14 @ 9:15 am
oh year----thanks for the "settings" tip.
its very easy.....you can ask in a textzone as in a button via
action="setting 'automixmode'"
action="setting 'fadelength'"
and will get the settings-paramater!
geposted Fri 26 Dec 14 @ 4:34 pm
djnice wtf?
which skin is that?
which skin is that?
geposted Sat 27 Dec 14 @ 9:46 am
its my modskin called "OrangeJuice" , based on dennyo controller V8 - in this moment only 2 Deck...
geposted Sat 27 Dec 14 @ 11:47 am
where can i find it?
geposted Sat 27 Dec 14 @ 2:08 pm
