Forum: Old versions
Topic: Can you have 2 V tranitions at once?
Blind pondering here, I don't use video but is it possible to have 2 V transitions at once? (essentially can you have VT's selected on invisible slots? not effect active but effect select) I'm a bit too plastered to think clearly (script wise) so I'm asking.
geposted Sat 27 Dec 14 @ 11:13 am
No, it's not possible.
geposted Sat 27 Dec 14 @ 1:32 pm
Thanks for the reply,
Fair enough, often blind pondering leads to dead ends. It's be quite something if you could 'layer' VTs though. I'd imagine it'd be a heavy on the processing though.
geposted Sun 28 Dec 14 @ 4:22 am
