whats up guys, so i got my buddy thats been using vdj and such and we usually share computers when we do our gigs, so i just got a quick question
he currently is running 7.0 pro and we love it.
i want to buy vdj pro on my own and such as i want it on my computer
if i buy the infinity package, do i only have vdj 8? or would i be able to like download say vdj 7.0 or like vdj 7.4?
if yes, how would i go about taking my buddys like history and cue points settings and moving it to my computer? is it a simple database copy and paste?
geposted Sun 28 Dec 14 @ 11:25 am
Yes, if you buy a full Pro Infinity license then that includes the download of VDJ 7.4.2
You can also ask support for earlier versions of 7 if required.
Using someone elses history, cue points etc. will only work if your system is set up exactly the same as his. Same user name, same directory structure, same file names and locations. That's not very likely.
You could use history purely for reference though.
geposted Sun 28 Dec 14 @ 11:48 am
Well we have our music files on our desktops and such so as far as music files it would be simple. Program files and such I'd be sure it simple... Might take some time to do but it's due able
geposted Sun 28 Dec 14 @ 12:49 pm
