I am not getting music sounding through my laptop but the track is playing on the deck and the config settings is only giving me advanced options to upgrade to VDJ pro.
I uninstalled everything and started from scratch but still have the same problem.
How can I get it going normal again??
Cheers.
Cheers.
geposted Wed 31 Dec 14 @ 5:39 am
With the LE Version the sound is routed through your controller.
Just connect your speakers to the master out ouf your controller.
geposted Fri 02 Jan 15 @ 5:35 am
Thanks for your reply
I don't have speakers yet, can I not use the speakers on my laptop?
geposted Fri 02 Jan 15 @ 6:57 am
No, unfortunately not. That's one limitation of your LE (limited edition) version.
geposted Fri 02 Jan 15 @ 9:14 am
In this video dose he not imply that you can use built in speakers and change settings in the config menu with VDJ LE?
https://www.youtube.com/watch?v=WYEJ2BjzXoc
geposted Fri 02 Jan 15 @ 5:06 pm
you need to also have virtual dj home edition installed , as the config is greyed out after the trial period finished , set the sound settings you want in vdj le in the home edition close it reopen le and then you pc speakers will work , i had to do this when i have it set up in my house for a party and then changed it back again before going out the road gigging
geposted Sat 03 Jan 15 @ 3:42 am
Hello uktwista
I have done that with the VDJ home edition and the VDJ 8 free download. I can get it working fine on the two of them only for 10 mins but it wont keep the settings for my LE version and still no sound coming from the laptop.
geposted Sat 03 Jan 15 @ 5:40 am
Why would you even be considering listening to music on laptop speakers?
They sound terrible. Even a pair of basic external speakers would be an improvement.
Plus, you'd be using your equipment as intended.
geposted Sat 03 Jan 15 @ 5:54 am
Yes I know what you mean they do sound bad.
I have no speakers that connect via the wego's sound card, that's why I want to use the laptop speakers or other speakers I have that connect to my laptops headphone jack in the meantime until I get sorted.
geposted Sat 03 Jan 15 @ 6:55 am
Earlier you said that you had no speakers!
If you've got speakers already, but they have a different connector, then go buy yourself an adapter cable. :-)
geposted Sat 03 Jan 15 @ 7:16 am
That looks great and should work with my speakers that I taught were going to be useless.
As you all probably can make out I'm new to all this stuff and learning bits and pieces.
Thanks for that groovindj I will get one of them and see how I get on, thanks.
geposted Sat 03 Jan 15 @ 7:59 am
