Hey guys can you give me some links, both RECENT info and tools? Thanks!
geposted Fri 02 Jan 15 @ 10:28 am
There are two parts to a skin - the graphics and the XML code. Therefore you'll need: Graphics editing software and XML editing software.
The graphics s/w should support PNG as this is the format used in VDJ 8.
For editing the XML, Notepad++ is a popular choice (for Windows PC).
I'd suggest starting out by looking at existing skins and making some small changes to those, to get to grips with how skins work.
geposted Fri 02 Jan 15 @ 10:34 am
ok Thanks.. :-)
geposted Fri 02 Jan 15 @ 10:42 am
geposted Fri 02 Jan 15 @ 12:20 pm
For Mac-User:
xmplify (XML-Editor)
Sketch (gfx-editor)
pixelmator (gfx-editor)
;o)
Sketch (gfx-editor)
;o)
geposted Fri 02 Jan 15 @ 12:29 pm
You're also free to put on this board any question. We'll try our best to answer them :)
geposted Fri 02 Jan 15 @ 2:45 pm
ok i really really need Help makeing a skin i have the skin maker Tool but i wanna make my very owen what do i need in order to build one from scratch :) please help me :/
geposted Tue 06 Jan 15 @ 6:48 pm
See answers above.
Also, please don't post the same question multiple times. Once is enough!
geposted Wed 07 Jan 15 @ 5:09 am
