Hi I have fallen for WDJ8 and the default skin (there's probably better but I like it).
I have mapped EQ kills to keys but when I use them there is no visual indication of what is on or off. Can this be enabled on the skin? If I right click the EQ knobs then they reduce to 0% both visually and audibly but if i use my mapped keys then only the audio changes.
geposted Thu 08 Jan 15 @ 11:39 am
Try this: that one is for eq_high
eq_high 0% ? eq_high 50% : eq_high 0%
If that doesn't work, try this:
eq_high 0% ? eq_high 50% : eq_high 0% & eq_kill_high
geposted Thu 08 Jan 15 @ 3:14 pm
um, how do you mean try? (sorry)
geposted Fri 09 Jan 15 @ 1:51 am
try to map :-)
geposted Fri 09 Jan 15 @ 2:16 am
ok ive assigned the following to the kill keys:
deck 1 eq_high 0% ? eq_high 50% : eq_high 0% & eq_kill_high
deck 1 eq_med 0% ? eq_med 50% : eq_med 0% & eq_kill_med
deck 1 eq_low 0% ? eq_low 50% : eq_low 0% & eq_kill_low
(same for deck 2)
works great but now i have press twice to get the EQ kill off - press once its killed, press again the eq knob returns to 0& visually but audio stays killed, have to press two more times to get the audio back to normal
any thoughts?
(same for deck 2)
any thoughts?
geposted Sun 11 Jan 15 @ 2:56 am
deck 1 eq_high 0% ? eq_high 50% & eq_kill_high : eq_high 0% & eq_kill_high
It is pretty poor there's no visual (nor a way to eq kill via the mouse)
geposted Sun 11 Jan 15 @ 10:58 am
AFAIK, you can temporarily kill EQs by rightclicking on the EQ knob with the mouse.
But that means you have to keep pressing the mousebutton.
geposted Mon 12 Jan 15 @ 4:59 am
Not quite, right click toggles 0%, 50%, but it isn't while pressed.
I've brought back the v7 click label = eq kill & added a visual
geposted Mon 12 Jan 15 @ 5:06 am
hows that done then?
geposted Tue 13 Jan 15 @ 3:30 pm
Something like this, but you'll need to learn a bit of skinning before it makes sense.
<group name="knobb" x="+0" y="+57">
<panel class="knobb">
<slider action="eq_high" dblclick="eq_high 50%" rightclick="eq_high 0% ? eq_high 50% : eq_high 0%" tooltip="EQ HIGH"/>
<slider action="eq_high" dblclick="eq_high 50%" rightclick="eq_high 0% ? eq_high 50% : eq_high 0%" tooltip="EQ HIGH" frommiddle="true"/>
<textzone leftclick="eq_kill_high">
<text format="HIGH"/>
</textzone>
</panel>
<visual source="eq_kill_high" type="onoff">
<pos x="+0" y="+42"/>
<size width="8" height="8"/>
<on x="1336" y="2700"/>
<off x="1336" y="2710"/>
</visual>
</group>
</textzone>
</panel>
</visual>
</group>
geposted Tue 13 Jan 15 @ 4:20 pm
Did clicking the labels kill EQ in VDJ 7? I didn't know that!
I do think it's a cool idea to have some hidden clickable areas in a skin that only you know about though.
geposted Tue 13 Jan 15 @ 4:49 pm
I think the EQ labels in ver 7 skin were just visuals , not buttons, but yes they were offering the info you wanted.
Maybe added.. will make a note to the Team.
geposted Fri 16 Jan 15 @ 5:13 am
