Ive had little to no luck with wireless microphones. am i doing something wrong? they always cut out when alot of people are in the room, but when im testing the mic before hand it works perfectly fine. am i doing something wrong? let me know because using a wired mic does not look good at a wedding reception
geposted Thu 15 Jan 15 @ 9:23 am
What type of wireless mic are you using (make and model)?
geposted Thu 15 Jan 15 @ 9:38 am
Hi,
It's always good to get the reciever mounted as high as possible, radio waves don't travel through people very well.
I use a system from line 6
Line6 XD-V55HS and a Line6 TX55 Handheld
I can use either the headset or the handeld on one receiver, it works pretty well.
geposted Thu 15 Jan 15 @ 10:15 am
For starters you need to make sure you are using a diversity wireless microphone system. They usually use two antennas and two receiver channels.
When people (bodies) or stray RF-signals obstruct or interfere with communications between the microphone and the receiver, a diversity system makes sure the best signal goes to your master output within nano-nano-nano-seconds.
I'm a wedding DJ. Anytime I start shopping for wireless mikes I look for the magic word= Diveristy
geposted Thu 15 Jan 15 @ 10:17 am
+1 Tom
geposted Thu 15 Jan 15 @ 10:26 am
Thanks-- would have helped my credibility if I spelled Diversity correctly at the end. ;)
geposted Thu 15 Jan 15 @ 10:34 am
happens to me all the time
geposted Thu 15 Jan 15 @ 5:55 pm
Wireless mics are the only area where I believe, you get what you pay for. Shure has never let me down in this department. But, I don't buy their low end models. I have had great luck with their PGX series. It's their mid level system.
geposted Thu 15 Jan 15 @ 6:30 pm
