Hi,
Using a Pioneer DDJ SX and VDJ 8.0. Sometimes there are sound issues when loading a song while music is playing. Can anybody provide the reasons this happens as in the options I need to play with so this doesn't happen any more??? I really need to get flawless performance here. Using a PC, quad core I7 with 8gb of RAM, very well kept and clean boot and all. Sorry for posting it here but I have no clear answer if it is a controller issue or software issue so I need to address it accordingly. This issue does not happen at other gigs when Im using CDJ 850s, only the SX so that narrows it down a bit.
1. Songs are already analyzed, not that it should matter.
2. Latency is at 512
3. Ultra Latency is off
4. Song load priority (which says to set low to prevent audio drop out while loading) - Set to Low.
Thoughts what else I need to play with or what the cause could be?
Thanks!
Thanks!
geposted Sat 17 Jan 15 @ 8:21 pm
Please do not post the same thing more than once. I have replied to the other post.
Thank you.
Thank you.
geposted Sun 18 Jan 15 @ 5:37 am
