Forum: Old versions
Topic: NEWBIE!! Problem
Hi all, I'm a bit of a newbie to virtual dj, I've downloaded the app on my Macbook Pro, my iTunes comes up bottom left but when I drag a song to play it doesn't work???????
Any help would be great
thanks
geposted Fri 23 Jan 15 @ 1:26 pm
AsTheDJPRO InfinityMember since 2008
thanks
Just some info about the app.did you DL the free Home or you have VDJ-7 home or 7/8 pro? one you add songs to data VDj will see it and play songs all iTunes format are MP3's in on mac's
geposted Tue 27 Jan 15 @ 12:15 am
