Forum: Old versions
Topic: Script Working one way not the other, WHY?
I'm trying to get a POI and a custom button to automate a slider and am having problems
What happens is as the POI is activated it first checks $T101 (has it been triggered)
if yes, it presses a custom button, the custom button increases the slider, it also gets the current beat adds a tiny bit to this number and uses the number to place the poi ahead of the playhead
if no, it sets the slider to a level (decided by a var) sets '$T101' to 1 and then presses the same custom button as before
($S101 is a sweep type and for now is a constant 1)
Where it falls down is, in the $T101 = 0 state it won't move the poi, $T101 gets set and the custom button IS pressed once (slider increases by 1%) but the poi won't move
POI
var_equal '$T101' 1 ?
____var_equal '$S101' 0 ?
________nothing
________: var_equal '$S101' 1 ?
____________custom_button 3 1
____________: deck 1 pause
____: var_equal '$S101' 0 ?
________nothing
____________get_var '$L101' & param_cast & deck 1 effect_slider 'flanger' 1 & custom_button 3 1 & set '$T101' 1
____________: nothing
var_equal '$T101' 1 ? var_equal '$S101' 0 ? nothing : var_equal '$S101' 1 ? custom_button 3 1 : deck 1 pause : var_equal '$S101' 0 ? nothing : var_equal '$S101' 1 ? get_var '$L101' & param_cast & deck 1 effect_slider 'flanger' 1 & custom_button 3 1 & set '$T101' 1 : nothing
Custom button 3 1
deck 1 effect_slider 'flanger' 1 +1% & var_equal '$D101' 4 ?
----deck 1 get_beatpos & param_add 0.02 & param_cast & deck 1 set_cue 3
----: nothing
deck 1 effect_slider 'flanger' 1 +1% & var_equal '$D101' 4 ? deck 1 get_beatpos & param_add 0.02 & param_cast & deck 1 set_cue 3 : nothing
*Edit* I have it working, but I had to put the triggered ($T101) query inside the sweep query, WHY IS THIS?
var_equal '$S101' 0 ? nothing : var_equal '$S101' 1 ? custom_button 3 1 & var_equal '$T101' 1 ? nothing : get_var '$L101' & param_cast & deck 1 effect_slider 'flanger' 1 & set '$T101' 1
geposted Thu 29 Jan 15 @ 11:05 am
