mapping.
How to assign different effects to the different pads?
I have chosen to use OVERLOOP as my first effect. And it works
But when I tried effect_active 2 for a different pad it keeps using the BACKSPIN effect. So i have only been able to map one effect successfully.
And the same for an effect_active 3
It switches to the BREAK effect.
Scripts, anyone?
Scripts, anyone?
geposted Tue 03 Feb 15 @ 12:07 am
Just tested here:
effect_active 2 "Beat Grid"
Worked fine for me :)
geposted Tue 03 Feb 15 @ 6:00 am
I bought used idj3 but no software where can i get one
geposted Tue 03 Feb 15 @ 6:42 am
Please don't hijack other peoples threads.
If no software was supplied with your IDJ3 (licenses are not transferable) then you can purchase a new license here:
Regards,
Scott
Regards,
Scott
geposted Tue 03 Feb 15 @ 6:45 am
Effectively mapped an effect for a second pad. but instead of mapping the reverb effect, it mapped the backspin. Not the desired effect I was looking for.
geposted Tue 03 Feb 15 @ 1:37 pm
Please give the exact mapping you used. I tested the mapping I provided above before posting and it worked fine.
geposted Wed 04 Feb 15 @ 9:23 am
Effectively mapped pad 1 and pad 2 with the correct script you provided. Thank you.
I finally got a 3rd pad to work, it wasn't registering for a second but it took.
had to go to work so i didnt get a chance to close out the program and see if itd work continuously . I will see if its still working correctly when I get back.
And finally the effect for a 4th effect command just would not stick. I was thinking there might be a limited amount of effects I would be able to script?
geposted Wed 04 Feb 15 @ 4:15 pm
hi.
no command to map (Virtual dj 7) the following options - for EFFECT- echodoppler I want to put a button on controler this choice '' BEAT '' and options
'' DECK 1 '' - '' DECK 2 '' which is below the ACTIVA
http://s27.postimg.org/o44156137/IMG_20150124_143140.jpg
geposted Fri 06 Feb 15 @ 12:30 pm
