As mentioned, I am using a MC6000 controller and the Fruit skin. When I spin the jog wheels, they are WAY too responsive. They speed the track up WAY too much or slow the track down WAY too much.
Is there any way to adjust this? If so, please let me know how to do this.
Many thanks.
Scott
Many thanks.
Scott
geposted Sat 07 Feb 15 @ 9:27 am
In Bend (CD) mode ?
Try to set the JogSensitivityBend setting to a lower value (e.g. 0.03 or less)
geposted Sat 07 Feb 15 @ 5:42 pm
Could you also please do the following :
- Backup and remove settings.xml
- Launch VDJ / Select my skin
- Please DO NOT go to any menu / check any layout settings
- Test with this brand new configuration if your problem persists
geposted Mon 09 Feb 15 @ 4:10 am
