I'm using "Define" for the first time and do not see examples of Level faders with sliders. The following is a code that currently works for one volume level control with moveable slider:
<slider action="deck 1 level" orientation="vertical" dblclick="reset" rightclick="temporary">
<size width="40" height="213"/>
<pos x="832" y="442"/>
<size width="45" height="222"/>
<up x="120" y="2098"/>
<selected x="161" y="2098"/>
<fader>
<size width="37" height="32"/>
<pos x="121" y="2060"/>
<mouserect x="125" y="2050" width="30" height="28"></mouserect>
</fader>
</slider>
But how do I define once to replicate later??
<fader>
</fader>
</slider>
geposted Thu 19 Feb 15 @ 3:49 am
<define class="slider" orientation="vertical" dblclick="reset" rightclick="temporary">
<fader>
</fader>
</define>
Then use:
<slider class="slider" action="deck 1 level"><pos x="832" y="442"/></slider>
geposted Thu 19 Feb 15 @ 5:26 am
Works great! Thanks
geposted Thu 19 Feb 15 @ 10:16 am
Do you also know the variable to get "master" volume? Would like to add master volume l.E.D.s
geposted Thu 19 Feb 15 @ 7:06 pm
You need a <visual> with source="get_vu_meter 'master'"
The code is available in the default skins too.
geposted Thu 19 Feb 15 @ 7:31 pm
Ahhh. I was looking all over for it. I thought I was looking at default, but it was a different skin.... lol
IT's what I was looking for.
One last thing with volume. What's the trick to only show a fully lit LED? Currently, when the levels bounce, each individual LED is lit from the bottom up. I would like the individual LED to be lit all at one or not at all.
Am I asking correctly?
geposted Thu 19 Feb 15 @ 7:43 pm
Working on a highly simplified, but detailed version of the NS7II.
geposted Thu 19 Feb 15 @ 8:03 pm
hmm u may need to define each "Led" as a separate button (or visual) and use something like ..
get_vu_meter 'master' & param_bigger 40% ? param_smaller 50% ? on : off : off
this will turn on a "Led" if the VU meter is between 40% and 50%
EDIT.. probably you need all Leds below to light up so the actions should look like..
get_vu_meter 'master' & param_bigger 40% ? param_smaller 50% ? off : on : off
Will light up the xth led if VU is over 50%
geposted Thu 19 Feb 15 @ 8:09 pm
So I used your suggestion and it worked on the master VU left... But having headaches trying to figure out to group everything so that I can easily replicate the work i've done, and just re-position 36 pixels to the right using a few lines of code.
I've look at so many example and getting super confused. I have defined the following:
---LEDS 1-11 DEFINED---
<Group name="LEDS-DEFINED">
-LED #1
<define class="LED#1" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 0% ? param_smaller 9.09% ? off : on : off">
<size width="8" height="16"/>
<pos x="939" y="620"/>
(Gray LED)
<off x="60" y="2120"/>
(Bright Red LED)
<on x="80" y="2282"/>
</define>
<define class="LED#2" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 9.10% ? param_smaller 18.18% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#3" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 18.19% ? param_smaller 27.27% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#4" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 27.28% ? param_smaller 36.36% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#5" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 36.37% ? param_smaller 45.45% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#6" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 45.38% ? param_smaller 54.54% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#7" type="linear" orientation="vertical" direction="up"source="get_vu_meter_left 'master' & param_bigger 54.55% ? param_smaller 63.63% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#8" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 63.64% ? param_smaller 72.72% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#9" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 72.73% ? param_smaller 81.81% ? off : on : off">
(Gray LED)
(Bright Red LED)
</define>
<define class="LED#10" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 72.73% ? param_smaller 81.81% ? off : on : off">
(Gray LED)
(White LED)
<on x="80" y="2102"/>
</define>
<define class="LED#11" type="linear" orientation="vertical" direction="up" source="get_vu_meter_left 'master' & param_bigger 72.73% ? param_smaller 81.81% ? off : on : off">
(Gray LED)
(White LED)
</define>
</Group>
and then:
<group name="VuMeter-Master">
(Background)
<button class="LedBG"><pos x="1107" y="436"/></button>
-LED #1
<visual class="LED#1" chan="1">
</visual>
-LED #2
<visual class="LED#2" chan="1">
<pos x="939" y="602"/>
</visual>
-LED #3
<visual class="LED#3" chan="1">
<pos x="939" y="584"/>
</visual>
-LED #4
<visual class="LED#4" chan="1">
<pos x="939" y="566"/>
</visual>
-LED #5
<visual class="LED#5" chan="1">
<pos x="939" y="548"/>
</visual>
-LED #6
<visual class="LED#6" chan="1">
<pos x="939" y="530"/>
</visual>
-LED #7
<visual class="LED#7" chan="1">
<pos x="939" y="512"/>
</visual>
-LED #8
<visual class="LED#8" chan="1">
<pos x="939" y="494"/>
</visual>
-LED #9
<visual class="LED#9" chan="1">
<pos x="939" y="476"/>
</visual>
-LED #10
<visual class="LED#10" chan="1">
<pos x="939" y="458"/>
</visual>
-LED #11
<visual class="LED#11" chan="1">
<pos x="939" y="440"/>
</visual>
</group>
-LED #1
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(Bright Red LED)
</define>
(Gray LED)
(White LED)
</define>
(Gray LED)
(White LED)
</define>
</Group>
and then:
(Background)
-LED #1
</visual>
-LED #2
</visual>
-LED #3
</visual>
-LED #4
</visual>
-LED #5
</visual>
-LED #6
</visual>
-LED #7
</visual>
-LED #8
</visual>
-LED #9
</visual>
-LED #10
</visual>
-LED #11
</visual>
</group>
geposted Fri 20 Feb 15 @ 12:30 am
You can move a group:
<group name="VU_METER" x="+100" y="+10">
Or
<group name="VU_METER" x="900" y="220">
Or
geposted Fri 20 Feb 15 @ 5:24 am
But do I have to copy and paste everything in the original group? or can I define what a group is like define class?
geposted Fri 20 Feb 15 @ 9:09 am
I guess in other words, can I define a group and just use the class id of the group for an element so that I can duplicate the group in another spot without having to redefine everything inside? I am trying to shorten the amount of code used since I need to do this a lot.
geposted Fri 20 Feb 15 @ 12:46 pm
Isn't this the easiest way?
<visual type="custom" source="get cpu" orientation="horizontal">
<size width="25" height="11"/>
<pos x="9" y="8"/>
<down x="9" y="773" nb="7" smooth="true"/>
</visual>
<pos x="9" y="8"/>
</visual>
geposted Fri 20 Feb 15 @ 1:29 pm
I don't know...
I tried the following:
<visual type="custom" source="get_vu_meter_left 'master'" orientation="vertical">
<size width="8" height="196"/>
<down x="60" y="2102" nb="11" smooth="false" />
</visual>
It's not the same effect. All LEDs come on and sort of move horizontal, not vertical.
</visual>
geposted Fri 20 Feb 15 @ 3:39 pm
