Forum: Old versions
Topic: Configuration/setup issues with Denon MC6000 & VDJ8
Ok guys forgive the ignorance here (obvious rookie) but I am trying to get a setup for VDJ8 and Denon MC6000. Having config issues (attached screenshot). I have updated the ASIO drivers from the Denon site but am having issues mounting the Bin file for the Firmware update (attached) as it says that the file is not supported. I am wondering if I need to have this Firmware update for it t work properly. I have also attached the screenshot of the ASIO driver screen. I have my setup for 2 decks not 4, so channel 2 is setup to USB 1/2 and channel 3 setup to USB 3/4 and the mixing mode is INT mix. Cant get any sound to the single speaker I am using. Some direction would be much appreciated.
geposted Fri 13 Mar 15 @ 2:55 pm
Disregard....was able to figure out how to install the Firmware....
geposted Fri 13 Mar 15 @ 9:20 pm
So you got everything working properly? I have the same setup but i'm having issues with the crossfader. Can you post a screenshot or your settings again or is what you have posted already correct?
geposted Fri 17 Apr 15 @ 8:03 am
