Using Automix with "Fade (Remove Silence)" set with a zero second fade often removes the very beginning of the next song. Assuming this can be fixed is there a way of inserting a short pause between tracks so playback ends up sounding similar to a non mixed CD?
geposted Mon 16 Mar 15 @ 4:05 pm
Did you ever solve this? I am having the same problem
geposted Tue 25 Aug 15 @ 8:50 am
This may be the problem. When a song is playing look at the track waiting. Make sure the fade start cue point is correct. If it appears that it is too far to the right then do the following: right click on the waiting track and select BPM Editor. In the BPM Editor you will see /2 & X2. If you click on one of these, if one does not work try the other one, the cue point will go back to the right position. I has this problem about six months ago and technical support claimed they fixed it. It is much better but I still have the problem from time to time.
geposted Tue 25 Aug 15 @ 2:29 pm
