new os x yosemite version is not compatible with vertual dj. it needs an update plz fix it fast
geposted Tue 24 Mar 15 @ 9:50 pm
I'm on 10.10 as well and it works like a charm.
What let you think it isn't compatible?
geposted Thu 26 Mar 15 @ 4:36 am
I'm even @ 10.10.3 (beta version) and it runs perfect on a macbook pro i5 retina 13inch.
geposted Thu 26 Mar 15 @ 4:16 pm
I have a Macbook Pro OS is 10.10.2, Denon MC6000, and VDJ 7.4.2. The midi works but no sound out of the Denon MC6000. My sound is coming out of the Macbook Pro speakers. We need this issue resolved.
geposted Tue 31 Mar 15 @ 10:58 pm
That's a simple audio routing issue. Go into Settings > Audio (should be the first option), and take a screenshot of that and paste it here. We will then tell you what to change.
geposted Sat 04 Apr 15 @ 9:22 pm
The MC6000 should be plug & play, with a large obvious button appearing in the audio config when it's connected.
All that's required is to select that button, which tells VDJ to configure the audio for an MC6000. Job done.
geposted Sun 05 Apr 15 @ 5:11 am
He's using v7.4.2 so won't have that.
As above if it is coming out of your macbook speakers then you have the wrong audio config.
Just noticed this post is a week old. Whoops!
geposted Sun 12 Apr 15 @ 1:56 pm
Mea culpa. I'm surprised that some folks are still using VDJ 7...
geposted Mon 13 Apr 15 @ 11:54 am
