Hi guys the setup was working fine yesterday, then today both CDJ-2000's load songs onto track A on VDJ.
Setup is as follows: VDJ+CDJ+Rane all plugged via USB.
Mac Sound Options set to : RANE2015 output
CDJ's are set to decks 1 & 2 via the Link.
VDJ Sound Setup is set to: http://screencast.com/t/jSPzbkPOnjl
Whats happening is that when we load a song with Deck A it goes to Deck A in VDJ UI. When load a song with Deck B, it goes to Deck A in VDJ. If we press the eject button on the CDJ, both go to DECK B and so on. Meaning, both decks can control a single side of virtual DJ at any given time. Any suggestions?
geposted Fri 27 Mar 15 @ 10:08 am
In Config->Mappers tab, click to select the CDJ2000. Then click on the small button right next to the menu ->Mapper Options
You should be able to see 2 x CDJs2000 and Deck Assignement for each one. Make sure the 1st is on Deck 1 and the 2nd on Deck 2 (or vice-versa)
geposted Fri 27 Mar 15 @ 1:16 pm
awesome thank you!
geposted Fri 27 Mar 15 @ 3:25 pm
