The numerical folders on the left pane of virtualdj 8 isn't in number order (lowest to highest) The folders that start with letters are in alphabetical order. How do I get the folders that has a number label (2014, 2008, 2013, etc) be sorted in ascending order
geposted Fri 27 Mar 15 @ 1:20 pm
Do the folder names have any leading whitespaces or zeros? That might mess up the sorting system.
Could you give an example / a list of folder how they're sorted in VDJ and how they should be sorted?
geposted Sun 29 Mar 15 @ 1:23 pm
Search in your unordered folder (in windows) for a .order file, delete it.
geposted Sun 29 Mar 15 @ 4:29 pm
please make sure that you only delete files that have NO file extention
geposted Tue 31 Mar 15 @ 6:36 am
