Forum: Old versions
Topic: Error message showing up when loading a song on either deck
I've been using VDJ for years, with simple mixing through keyboard shortcuts, as well as using a Denon DN-MC 6000. There was about a month or two period where I hadn't opened up the program, and i recently opened it, to come across the following problem: I locate/load a song from my iTunes on the left search area, and it says "error," and the song cannot be loaded. I tried making new playlists with new songs in them, and came across the same problem. The only way I can seem to get around this problem is by manually finding the .mp3 file of the song, and dragging it from Finder onto the deck. This seems a bit annoying. Would you guys happen to know what the problem is?
I am running Version 7.0.2
I have not changed any preferences (that I know of, at least) for this problem to occur.
geposted Sat 28 Mar 15 @ 11:43 pm
