Dear friends,
please help
For many years i was using VDJ7.04 PRO on windows and everything was fine
last couple of days i bought a macbook pro, the latest model, and i plug in my pioneer DDJSB controller. i made the appropriate config and everything is working fine between the controller and virtualdj 7.04pro, but THERE IS NO SOUND COMING FROM THE HEADPHONES (the headphones are connected on co0ntroller)
just keep in mind that there is nothing wrong with my mac sound, because when i make the config built in outpout, sound is normal comes from mac
i would appreciate ur hekp...
please help
geposted Sun 05 Apr 15 @ 11:02 am
no one???
geposted Tue 07 Apr 15 @ 6:44 am
To use this controller you would need to update to our latest version7 build.
You will get this when you just enter your Pro license key under MyAccount/MyLicenses.
After that can you download from there your latest version7 build for use with the DDJ-SB.
7.04 is a very old build and can cause problems!
geposted Thu 09 Apr 15 @ 2:58 am
problem sovled!!!
thanks a lot!!
thanks a lot!!
geposted Sat 11 Apr 15 @ 1:50 am
