Topic: Custom Key commands Crash VDJ 8
I have been enjoying VDJ 8, but I found an annoying bug that is making my butthole pucker while I DJ. I have mapped all of my keys in VDJ to match serato, as that's what I'm used to. I love VDJ so much more, so I've been using it religiously lately. During my last 2 proms, when I hit the Shift + Right combo to load the right deck, it crashed the software.. Music continued playing, but the screen went gray, and the "unresponsive" dialog came up.
I can duplicate this.
Any Idea what this is all about?
Thanks!
6 Core Intel Processor, Windows 7 64 bit.
Thanks!
geposted Sun 12 Apr 15 @ 11:58 pm
What is the action you have mapped to that key combination?
geposted Mon 13 Apr 15 @ 3:44 am
Thinking out loud, could this be a modifier "sticking" issue?
As a test, use the command as usual but be certain that SHIFT is the last key to be let go, does it crash then?
geposted Tue 14 Apr 15 @ 3:56 am
